How to Install Sound Packs
Important
You must be on Sensory Percussion version 2.1.4 or later to install Sound Packs
Sounds packs are a great way to expand your sound library. They are available for download from the Sunhouse Downloads page. Once you have downloaded the .spz file, you can install the pack in two ways:
Install from the File menu
Under File in the top menu bar of Sensory Percussion 2, select Install Sound Pack... and locate the the .spz file you downloaded.
After opening the .spz file, you will be prompted to install the pack. Click Install to install the pack.
Once you've installed it, the new pack will now appear in the Sound Packs section of the Library.
