Sensory Percussion Hi-hat Sensors
A photo of an Evans db One hi-hat with the Sensory Percussion hi-hat sensor attached
The hi-hat sensor attaches to the top of the hi-hat stand, which is the part of the cymbal you actually hit. We've included a gooseneck cable arm that get the cable up and away from the cymbals.
The Sensory Percussion Hi-hat Sensors use the same contactless sensing technology as the drum sensors. The sensors use a 3.5 mm TRS cable to connect to the EVANS Sensory Percussion Portal. When the sensor is correctly connected, you will see an indicator light turn on.
The cymbal sensor is designed to work seamlessly with EVANS db One cymbals.
An overview of the Hi-hat Sensor features An overview of the Hi-hat Sensor features
