EVANS EMAD Bass Drumhead Adapter
When using EVANS EMAD bass drumheads with Sensory Percussion, you will need to use the included adapter to allow the drum sensor to properly attach to the drum. Simply snap the adapter onto the sensor and you're good to go.
