Sensory Percussion Cymbal Sensors
A photo of an Evans db One cymbal with the Sensory Percussion cymbal sensor attached
The Sensory Percussion Cymbal Sensors use the same contactless sensing technology as the drum sensors. Usable on any cymbal stand with nothing attached directly to the cymbal. The sensors use a 3.5 mm TRS cable to connect to the EVANS Sensory Percussion Portal. When the sensor is correctly connected, you will see an indicator light turn on.
The cymbal sensor is designed to work seamlessly with EVANS db One cymbals.
An overview of the Cymbal Sensor features An overview of the Cymbal Sensor features
