Grid Pads
Like Drum Pads, Grid Pads controllers allow you to distribute modules across different pads, but, in all likelihood, the Grid Pads will be receiving input from a Pads Input that you set up to be controlled by a pads-based MIDI device.
But, just like Drum Pads, once you've added a Grid Pads controller to your set, you can drag and drop any other kind of generator or controller onto the pads and trigger and control them with your device.
