Drum Sensor Inputs
After choosing a Snare, Kick, Rack tom, or Floor tom sensor type from the add menu in the hardware inputs panel, you'll see a small form to fill out with some information about the drum you want to add. Some of this info will help us set the right default settings for that drum type, and some of the info is just for you to keep your inputs organized.
A screenshot of the create sensor input module, asking for information about the drum
Sensor Input Parameters
An overview of a Drum Sensor hardware input module An overview of a Drum Sensor hardware input module
On the right side of the sensor input, you can toggle between Pads, Sensitivity, and Threshold views:
The Pads section of a sensor input
