MIDI Inputs
An overview of an midi input module An overview of an midi input module
MIDI inputs allow you to use external MIDI controllers or keyboards to control parameters within Sensory Percussion. Map the knob of your controller to the dry/wet of an effect, or bypass this effect with a key on your MIDI keyboard.
Once you have a MIDI hardware input connected to a MIDI virtual input, you can use your MIDI device to control things by creating a MIDI Control assignment on the parameter you want to control.
