Analog Inputs
Analog Inputs can refer to a variety of different instruments you might want to connect to Sensory Percussion. The example above is a vocal mic, but there are also options for Aux Inputs, Synths, Mixers, and Guitars. Essentially, any sound source that can connect to the inputs on the EVANS Portal can be used as an Analog Input.
With Analog Inputs, you can monitor a whole band through Sensory Percussion! Make each instrument its own layer and add effects from within Sensory Percussion to vocals, guitars, and other non-drum instruments, all while mixing them independently from each other.
