File Menu
A screenshot of the file menu dropdown
The file menu is located in the top left corner of the software. This menu is where you can manage your sessions.
The file menu has the following options:
New session
This will close whatever session you have loaded and create a completely blank session. From here, you can start building your own sets from scratch, or drag and drop pre-made assets from the library. When you create a new session, your work won't be saved to disk until you select Save session or press + s, at which point you'll be asked to name your session.
Load session
This will open up your finder/file explorer and from here, you can open a previously saved session from your computer. Session files have the extension .sp2
Open Recent session
This will show you a list of your recently opened sessions, and you can choose which one to open from there.
Save session...
Selecting "Save session" will save any unsaved changes to disk. If you are working in a new session, you'll first be asked to name your session a choose a location to save it.
Save session as...
Save as will make a copy of whatever session you have open with a new name of your choosing. The new file will be opened as the current active session.
Edit session info...
Selecting "Edit session info" will open a dialog where you can edit the metadata for your session, including the session name, description, credits, tags, and a version number. This can be useful especially if you plan on exporting this session as a soundpack.
Collect and save session...
This option will save your session and collect all the assets used in the session into a single folder. This is useful if you want to move your session to a different computer. Samples from the core library and installed packs will not be included in the collected session and need to be installed separately on each computer.
Install soundpack...
Use this option to select a .spz file from your file system to install a Sunhouse soundpack. Soundpacks are collections of samples and presets that can be used in Sensory Percussion.
Export soundpack...
This option opens a dialog that allows you to export your current session as a soundpack .spz file. You can choose which presets and samples to include in the soundpack, as well as edit the soundpack metadata such as name, description, credits, and version number. This is useful for sharing your custom presets and samples with others or for backing up your work. Learn more.
Load demo session
The demo session comes with Sensory Percussion and includes 11 presets that demonstrate the best of what Sensory Percussion can do. These sets range from rich chordal kits, to detailed acoustic drum mappings.
Load inputs
This option will allow you to select a .spi hardware input list from your file system. Warning: any changes you've made to your currently loaded inputs will be overwritten - so make sure you choose "Save inputs as..." if you want to keep your changes.
Open recent inputs
This will show you a list of your recently loaded input files.
Save inputs As...
Selecting will allow you to save your current hardware inputs to a .spi file for later use or to transfer to a different computer.
Load outputs
This option will allow you to select a .spo hardware output list from your file system. Warning: any changes you've made to your currently loaded outputs will be overwritten - so make sure you choose "Save outputs as..." if you want to keep your changes.
Open recent outputs
This will show you a list of your recently loaded output files.
Save outputs As...
Selecting will allow you to save your current hardware outputs to a .spo file for later use or to transfer to a different computer.
