Sensory Percussion Drum Sensors
The Drum Sensors use contactless sensing technology to track your playing with maximal responsiveness. The sensors use a 3.5 mm TRS cable to connect to the EVANS Sensory Percussion Portal. When the sensor is correctly connected, you will see an indicator light turn on. Use the thumb screw on the top of the Sensor to lower the drum clamp to attach it to your drum.
The Sensor is designed to fit most standard snares and toms with metal or wood hoops and kick drums with wood hoops.
